586,075 active members*
3,798 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Predator wont run my V24 file
Results 1 to 7 of 7
    Feb 2011
    38
    In V24 Mill, I would like to use the advanced (blue icon) Predator that came with my package. My files will not run period. Can someone walk me through the process of using this feature?
    Erik
    Dec 2008
    4548
    Quote Originally Posted by erikh206 View Post
    Hey Eirk,
    So you mean the Predator "virtual CNC".............. Can you verify under Help-license that you have Simulation level 3 checked in green?
    If so, then after you generate toolpath, you go to modules Virtual cnc and the part should run. If you have fooled around with trying to config the properties of the virtual cnc, it is very easy to mess it up so it doesnt run. The easiest thing would be to get a good removal and just re-install.
    There is also possibly some type of program you have created that doesnt fit the machine config? Can you not make a simple default arc and profile toolpath and run it?
    If you are not licensed for the level 3, then all you have is a right clcik on the milling stock and choose verify.
    Apr 2009
    3376
    In V23,level 2 simulates with vitual preditor.Don't open the preditor with the fancy blue icon.After you create your tool path,do as Burr said,go to modules/virtual cnc.
    May 2013
    701
    I think its kind of like some Icons that come on computers. Just because it's there doesn’t mean we've got it , its just advertisement to let you know it's available so you buy it.
    That Blue Icon is on my desk top also but that doesn't mean that it works.
    I think that Bobcads new simulate in V25 is doing some what the same, but then again that’s just my thoughts.
    So yes check for License first its saves a lot of time.
    Feb 2011
    38
    Ok, I looked at the help/lic. page and level 2 and 3 are not checked....... neither is the virtual simulation high-lighted on the modules bar. Shame on me. :-)
    Thanks guys for the help!
    Dec 2008
    4548
    Ok, I looked at the help/lic. page and level 2 and 3 are not checked....... neither is the virtual simulation high-lighted on the modules bar.!
    Yeah, that means you dont have the full blown virtual cnc, but, the program is still part of the install. It will be the "verify" that you get from the cam tree.
    Feb 2011
    38
    I guess I should have listened to the salesman better......
    Thanks again.
  1. BobCad back to crashing, and Predator Editer wont work
    By Martin 007 in forum BobCad-Cam
    Last Post: 01-17-2013, 08:29 PM
  2. NC Studio Z axis wont work with PLT File
    By Palmpro Stu in forum Uncategorised WoodWorking Machines
    Last Post: 06-19-2012, 10:08 AM
  3. file wont run on mach 3
    By Justin Cavender in forum DIY CNC Router Table Machines
    Last Post: 03-21-2011, 06:57 AM
  4. Predator DNC 2008 Default file directory
    By bunta in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-10-2010, 11:19 PM
  5. Does Predator allow a file transfer via DNC?
    By Fastest1 in forum DNC Problems and Solutions
    Last Post: 08-24-2010, 01:48 AM
