586,108 active members*
3,084 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Servo motor as a DRO on milling machine?
Results 1 to 8 of 8
    Dec 2009
    25
    I've built a cnc router a couple years ago and am about to retrofit a bridgeport. CNC router uses stepper motors and I'm a little unfamiliar with servo motors.
    My question is if I retrofit the milling machine with servo motors, using gecko drivers, will mach3 show the position if you turn the handles manually? Sort of a poor mans DRO. I'm sure this has been asked and answered somewhere but I'll be damned if I can figure out where.
    Also, my steppers have a lot of "drag" when they are off and you move them manually. Do servo motors do the same thing?
    I'm not too concerned about backlash compensation in the DRO as I figure its basically like using a manual machine except your looking at a screen instead of the dials.
    Thanks everyone.
    24221
    Mach closes the servo loop to the drive, not to the controller/HMI so it cannot show actual position, only anticipated posn.
    Servo's do not have the inherent Indent that steppers have, so when not energized they should rotate freely.
    Al.
    Albert E.
    Dec 2009
    25
    Al.
    So in other words the readout on mach3 will not increment if the servos are turned manually. Did I read that correctly?
    24221
    Yes.
    Al.
    Albert E.
    May 2005
    3920
    Quote Originally Posted by strangetanks View Post
    I don't know of any adaptations that allow Mach 3 to do that. In the case of the Gecko drive the encoder feedback goes to the motor amp. You would need a system that allows encoder feedback to the CNC software, EMC can do this from what I understand. It might be worth checking out Mach 4 when it comes out. The Mach guys are giving Mach 3 a massive overhaul for the Mach 4 version, I don't know if it will allow position feedback closer through Mach though.
    Servos won't have the same issues as steppers as the technology is completely different. However servos won't allow you to move an axis if powered up and enabled. Some systems allow you to move things around if the servo is disabled. Others may cause problems due to voltage feedback to the amp when the motor is rotated.
    Thanks everyone.
    I wouldn't say that, using a DRO, especially a good one with lots of helpful features, is a different experience. A DRO that doesn't have mechanical lash in its installation frees you from the mental gymnastics required to be sure that all backlash is taken out before starting a cut.
    May 2005
    3920
    Mach 3 Puts out step and direction signals and thus doesn't support such feedback in its basic form. The KFlop guys have a Mach front end for their hardware. I'm not sure what that afford you though. So best to talk to them or get on a forum oriented to their hardware The KFlop site is: Dynomotion | Motion Control Boards. I don't have any of dynomotions hardware or software so you will have to get info from them.
    Oct 2004
    832
    There are controllers available for Mach that will feed encoders back to Mach to update the DROs.
    I use the CSMIO/IP-A controller, from CS-Lab, on my Chiron FZ12S and it updates Mach from the encoders. If I rotate the motors manually when disabled Mach is updated, if I E-Stop then Mach knows where it is etc etc. It however is for use with analogue control servo drive/amps and not Step/Dir.
    I am not certain but I think the Hicon from Vital Systems may feed the encoders back to Mach but you would have to check up on that, it is for use with Step/Dir drives.
    Here is my Chiron just in case you are wondering what one is
    Hood
    https://www.youtube.com/watch?v=JS9mh_iMing
    Dec 2009
    25
    Thanks for the info everyone, I'm sure I'll have more questions when I start really digging into this project. The DRO function while nice isn't all that important to me and the relatively small amount of machining I do.
  1. Cannibalize Industrial Robot Servo System to Retrofit Milling Machine???
    By GM1G in forum RC Robotics and Autonomous Robots
    Last Post: 05-16-2010, 03:53 AM
  2. Single Phase Motor for Bridgeport Milling Machine
    By Bilkas in forum Bridgeport / Hardinge Mills
    Last Post: 11-27-2009, 01:37 PM
  3. Need servo motors for desktop CNC milling machine
    By PKaren in forum Servo Motors / Drives
    Last Post: 12-19-2006, 01:01 PM
  4. VFD & 3 Phase Motor for Milling Machine.
    By Willyb in forum Benchtop Machines
    Last Post: 03-14-2006, 05:01 PM
  5. What stepper motor, for a milling machine?
    By cncadmin in forum Stepper Motors / Drives
    Last Post: 03-23-2005, 10:09 PM
