586,075 active members*
3,691 visitors online*
IndustryArena Forum > CAM Software > CamBam > Adobe Illustrator eps not showing up properly in CamBam
    Feb 2012
    10
    I am trying to bring my Logo from Adobe Illustrator to CamBam in an .eps format. The letter portion of the logo comes over no problem, but the image portion is not there. any thoughts on what the issue might be?
    Jan 2010
    18
    Hello,
    cambam don´t work with the eps format. CamBam try to open a dxf as a nc file.
    I work with illustrator (CS6) , export as a Autocad DXF (Verion 2000/LT2000) and open it in cambam.
    When working with dxf the measuring system is not set from Illustrator. And you have to clean the polylines in cambam, with the "arc fit" function and reducing the nodes.
    ralf
    Jan 2007
    235
    Illustrator will export as .dxf
  1. Adobe Illustrator to VisualMill
    By gmesheau in forum Visual Mill
    Last Post: 03-23-2017, 11:29 AM
  2. importing from Adobe illustrator
    By fourperf in forum Solidworks
    Last Post: 11-29-2010, 08:43 AM
  3. Adobe Illustrator and TMcad
    By LenMcC in forum Torchmate
    Last Post: 03-30-2009, 05:59 PM
  4. Adobe Illustrator to CNC software?? HELP
    By merlin1974 in forum Uncategorised CAM Discussion
    Last Post: 07-23-2005, 09:06 PM
  5. Adobe Illustrator Files
    By JOE65 in forum Autodesk
    Last Post: 02-09-2004, 11:20 PM
