586,393 active members*
2,761 visitors online*
Results 1 to 6 of 6
    Dec 2014
    ACRAMATIC 2100 problems
    I have a Sabre750 with the following symptoms:
    On startup the unit DFS5 LED green -CPU blinks and in the same time i dont have command on contactor M20 and no power supply voltage, also lubrication unit, pedant key have no power
    The program runs but sometimes do not recognize the keyboard. On the screen at startup appears the following errors:
    1: APPLICATION ERROR. APPLICATION STARTUP TIMEOUT. THE NAME IS EXE CNC.EXE
    2: NC BASE ENGINE FAILED
    3: MWLIST.VBX (S_CURPOS_PGM [0]). SIZE VALUE IS ZERO .......
    Can anyone to give me a advice?
    Dec 2006
    584
    Re: ACRAMATIC 2100 problems
    It sounds like you may have a bad hard drive that is not loading software files. The newest software is NT4.0 service pack 6. How old is your hard drive???
    Mike http:// cncmachineservices.com
    Feb 2008
    12
    May be cmos battery is out. Try replace (cr2032), goto BIOS menu, set date-time AND set off any power management system. The same in realtime board, ONLY if battery is too dead. If you have RT board without PM system (recognize by chipset - if u see pins of any chip, this is propably w/o PM. If chips ic PGA ,propably have it - get attetions)
    Sep 2010
    1765
    and the blinking vfs5 LED is totally separate issue: usually means you have lost the internal program inside the spindle drive. To repair that we need to replace the internal BRAM chip and reprogram the VFS5 - not something that can be done in the field.
    Might this machine have been turned off for years and you are just now bringing it back to life?
    Sep 2010
    1765
    my last reply ASSUMED you had no wires/connectors MISSING on the VFS5 drive; perhaps I should not have ASSumed?
    Because the LED WILL blink showing drive is in autobaud state - IF connector C7 26 pin ribbon cable of the BDS5 located at top rear of drive has been removed.....
    Dec 2006
    584
    Did you get a new hard drive?? Did this fix your problem?? Let us know what is happening with this problem!!!
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Acramatic 2100 help!!
    By SBAGHAEI in forum Cincinnati CNC
    Last Post: 07-14-2016, 08:28 PM
  2. Acramatic 2100 Help
    By john333 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2011, 03:09 AM
  3. acramatic 2100 dnc problems
    By stevewortley in forum Cincinnati CNC
    Last Post: 07-30-2010, 06:06 PM
  4. Acramatic 2100 Problems
    By Clawsie Machine in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-15-2005, 02:38 PM
