586,052 active members*
4,159 visitors online*
Results 1 to 10 of 10
    Jan 2010
    5
    Post processor for Weihong NK105
    Hello,
    I bought a new chinese CNC (6090) with the Weihong NK105 system integrated
    Attachment 189852
    My supplier told me I must generate the G-code by using axyz posprocessor. The point is I tried to do it but CNC can't read the file. I recived a file by email from my seller and he told me the compatible file must be like this file. The issue is I don't know how to generate this file with this structure. I am beginner in machining world and I have no idea how to solve the problem. I use Catia, Solidworks, Artcam and Mastercam. I would like to know if someone can help me, please. I enclose a reference file that works in my cnc.
    https://dl.dropboxusercontent.com/u/.../Buddha.nc.zip
    Thank you in advance.
    Nov 2009
    314
    Hello ,
    It was a Buddha in simulate . Normally the DSP handle can read format like .nc and .mmg . This format can be found while you are saving the files . Some advanced machines 4 axis or 5 axis can do much more work but in need help of posprocessor . Why don't you ask the seller to do a screen video to show the operation for you ? To compare where the point is . I think it will helps a lot .
    Best regards,
    Mary Lee
    Jan 2007
    1795
    this file you posted has no any settings but spindle rpm..
    the generic g-code from any cam program should work..
    you might edit the g-code postprocessor, or ask help on proper forum..
    on artcam forum on the verified area even you can find posts about this..
    the reason for this barebone codeing, because youll set federate trough on the handheld unit..
    I would suggest you contact machine seller and buy an ncstudio control.. or a mach3 control for your router..
    both of them low cost and worth to replace the dsp control..
    ncstudio, works with separated processor ... for 3 axis works very well
    SALE CNC Router Milling, CNC Laser, CNC plasma machine, China, Servo Motor Drive, UK, USA, Italy, Spain, Thailand
    if you have more than 3 axis you can try the mach3 control
    I think the dsp control was developed avoiding a costly computer kept busy with router control.. since that computers are got on very low price so theres no more reason for the dsp control...
    Jan 2010
    5
    Hello EXLASer.
    During last 2 weeks I have written many times to my seller about it and it has been pretty frustrating. Nobody can tell me anything about, just Artcam, Mastercam, etc. are compatibles with DSP. The question is HOWWW! It is amazing and a waste of time. They have not got idea.
    Jan 2010
    5
    Quote Originally Posted by victorofga View Post
    Hello Victorofga.
    It's quite interesting your comment. I thought DSP would be easier than Match3, but now I think it had been better the other. I will try to ask in Mastercam forum about the postprocessor. I don't think I am the only one have had problems with a DSP.
    Thank you.
    Jan 2007
    1795
    chop3d
    again.. the file you posted don't have ANY specification..
    means everything is in the handheld control
    means you need only a simple, generic gcode and youll set probably federate, spindle rpm, coolant from the handheld unit
    the rapid and linear interpolation probably enough.. these controls knows the continuous velocity
    G00
    G01
    migthbe arcs can be processed too..
    your reseller might cant help
    ask weihong directly...
    Contact Us?Shanghai WeiHong Electronic Technology LLC.
    they answer for email.. I believe even for phone too..
    if you have difficulties yet... then you can shift to mach3...
    that will cost an extra 160-200, but it still a deal ...
    Nov 2009
    314
    Hello Chop3d ,
    I attached 3 pictures while saving files by artcam . 10 is our postprocessor name while saving ;11 is your manufacture says but I do not sure if it work ;13 is normal operation which we and most people did ,chose the format mmg . So you can test with the mmg first i think ,it should work .
    Attachment 191172
    Greetings ,
    Mary Lee
    XYZ Machinery
    Feb 2009
    95
    Hi, today I had a meeting with this WeiHong DSP controller trying to help a person who bought a router from China.
    There was no documentation about drive screw pitches and stepper microstep configuration but with some measuring, reading the tables on the stepper drivers, calculation and guesswork the machine came to life and movements are calibrated.
    But the big problem is how to generate a G-code file for it when no CAM program available to us has anything near to this name in the post processor list. Using the router in manual override mode with fixed feeds and speeds makes it suitable only for some basic work. Which is a shame for such a large router. One cannot do complex tasks with different tools.
    There is a demo file in the controller memory with Chinese name which I copied to a PC and had a look at. There are some header codes which seem non standard. At least I am no so well acquainted with G and M codes, so I have to look in some reference documents to see if they are from the standard set.
    The documentation is poor. Limited only to user interface and some settings. Nothing specific about the G-code functionality.
    BTW, file extension is not important. All G-code files are plain text files, readable in any text editor or viewer.
    Jan 2007
    1795
    dragonfly
    check artcam express out..
    it will produce toolpath for many type work..
    from simple 2d toolpaths, vcarving reliefmachining, photocarving it makes everything..
    it imports virtually all used meshformat of 3d models.. and can be toolpathed..
    cost 150 dollar or 220 leva.. and with visacard you can buy directly from delcam, or theres a bulgarien delcam office...
    DiTra íà÷àëî
    тел.: (+359 2) 91 91 2
    the express site to buy directly from delcam,,
    ArtCAM Express - Powerful CNC Software For Woodworking, Sign Making, Routing and Engraving
    theres some demo to download..
    also please note express working very well without any addition module..
    modules has importance only for busssiness use..
    all module is a speciality function.. what not necessary for beginners..
    Feb 2012
    87
    Re: Post processor for Weihong NK105
    Quote Originally Posted by EXLASer View Post
    Hello Chop3d ,
    Attachment 191172
    Greetings ,
    Mary Lee
    XYZ Machinery
    Hello EXLASer, I wonder if you have a postprocessor for Syntec 10A, thanks.
  1. DSP or Weihong control system
    By cup67 in forum WoodWorking Topics
    Last Post: 09-17-2013, 04:16 PM
  2. Question on the menu panel WEIHONG NK105 g2
    By andu in forum Machinery Manuals / Brochures
    Last Post: 04-19-2013, 01:38 PM
  3. Nk105 G2 User manual
    By AmicX in forum Machinery Manuals / Brochures
    Last Post: 08-10-2012, 11:18 AM
  4. Weihong OS
    By Chris Zenda in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-03-2008, 02:35 PM
  5. DSP or Weihong control system
    By cup67 in forum DIY CNC Router Table Machines
    Last Post: 06-11-2008, 02:26 AM
