586,971 active members*
3,059 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V25 How to create a mold cavity from an imported file
Results 1 to 9 of 9
    Mar 2012
    1570
    This video shows how to open a STEP file rotate it in position and created a top and bottom cavity.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jan 2012
    41
    I don't wanna be a downer because I do really like the boolean subtract functions but anytime your geometery isn't nice square things with uniform radii.. bobcad crashes when you attempt something like this. So then you gotta break the solid up and basically do it one surface at a time till you find the surface that it crashes on
    Mar 2012
    1570
    You can use this feature on complex geometry, it all depends on the solid you are working with. If you have a sample part you are having issues with, let me know and I'll point you in the right direction. You can email me the file and we can work on it together.
    My guess is there is something "wrong" with the file in the first place, so send me a sample and let's see.
    Al DePoalo
    Mar 2012
    1570
    Here is the same part showing some of the surfacing tools you can use. There also were some dropped surfaces and I show how to repair them...
    Al DePoalo
    Jun 2012
    514
    very helpful!!!!
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    Mar 2005
    368
    Giving you a like, but wouldn't split this where you did....
    Mar 2012
    1570
    This really isn't a mold it's a pattern and the split was based on what the customer wanted to do. Moldmaker I am sure you have more experience on this type of work then I do, Based on what you can see where would you split the part?
    Al DePoalo
    May 2013
    701
    Al
    How much draft, and what type of material is going to be injected can help in figuring any mold parting line. Some of the injection foam molds that we have built need a minimum of 15 deg. draft.
    Your Video is a Excellent example of basic mold making Using Bobcad solids and will help many. Keep up the good work.
    Thank You Al
    Mar 2005
    368
    Quote Originally Posted by aldepoalo View Post
    Al, patterns are completely different animals than injection molded parts... but if I were working with a customer that wanted an injection mold built, on the cheap, it would look like this:
    Attachment 190112Attachment 190114
  1. Finishing a Mold Cavity
    By eliot15 in forum GibbsCAM
    Last Post: 08-05-2011, 02:52 AM
  2. Create Stock Around Imported Solids
    By thebowman in forum Esprit
    Last Post: 01-04-2010, 07:16 AM
  3. v22 mold cavity help
    By chromic20 in forum BobCad-Cam
    Last Post: 09-23-2008, 11:07 PM
  4. create mold cavity
    By Rob 1264 in forum Uncategorised CAD Discussion
    Last Post: 05-09-2008, 05:04 PM
  5. Mold cavity
    By kojack in forum MadCAM
    Last Post: 11-01-2007, 08:22 PM
