586,036 active members*
3,477 visitors online*
    Apr 2013
    How to setup JOG control to move 2 axis with each direction key
    I need to setup the Mach3 Jog so that each key moves 2 axis at the same time. Example arrow key left right moves X and A simultaneously, and arrow key up/down moves Y and Z axis simultaneously. x, a, y and z are all independent axis not slaved and I cannot slave them as the 4 axis are needed when running g-code.
    Sep 2012
    1195
    Do you have to use a keyboard or do you have external buttons for jogging? I may be wrong, but it seems like Mach does not recognize the use of a hotkey as an input you can reference in a script or brain. It also seems to only do the first task it sees in the hotkeys setup. If you were to use an input with a signal from an external button, I'm almost certain you could assign it two (or more) functions by simply setting their port/pin number to the same input in the Config-->Port and Pins window. I'll try it to verify, but I don't see why it wouldn't work that way.
    Apr 2013
    Thanks mmoe, I am using keyboard only and tab for job mode. I tried assigning duplicate pins in ports and pins already but it didn't work with keyboard. All I want to do is be able to use the 4 arrow keys to move the 2 horizontal and 2 vertical axis simultaneously for manually cutting foam boxes into sheets.
  1. x axis will only move 1 direction
    By brent48 in forum Stepper Motors / Drives
    Last Post: 11-09-2010, 06:25 PM
  2. A Axis and Step and Direction Spindle Setup
    By mklb in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2009, 02:19 PM
  3. Rapid move axis control
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-15-2008, 03:51 PM
  4. x axis will only move one direction
    By CATCH22 in forum Mach Mill
    Last Post: 12-17-2007, 03:53 AM
  5. 2.5 Axis Direction Control
    By ee_cnc in forum LinuxCNC (formerly EMC2)
    Last Post: 11-21-2007, 03:42 PM
