Hello everyone,
I have been cutting alot of 16mm MDF and will be soon cutting 16mm Melamine as well.
I'm using a 1/4'' down cut spiral with a doc of 4mm'ish. This means im having to take 4 cuts. This is working ok but im having to constantly suck up the saw dust behind the cutter otherwise it becomes compacted.
What cutter do you suggest when you have to take multiple passes but you also want the clean cut finish that you get with a down cut spiral??
Would a better vacuum solve the problem??
Never used a compression bit. Would they work?
Thanks.
