586,116 active members*
3,474 visitors online*
    Sep 2011
    31
    E-Stop & Home/Limits not working
    What I have:
    C10 BOB
    NC E-Stop connected to INPUT #10 terminal and the 5V terminal next to it.
    Home/Limit Switches (OMRON) wired NC in series connected to INPUT #13 terminal and the 5V terminal next to it.
    After setting up in Ports/Pins and applying the settings I pressed the E-Stop while in the diagnostic to verify it was working and nothing happened tested the home/limit switches the same way and no response from hem as well.
    I greatly appreciate your help and thank you for sharing your time and knowledge.
    Craig
    Mar 2004
    1806
    Do you have the pins as active HI or LOW?????
    And do you have pullup or pull down resistors on the pins?
    I am just guessing as to possible problems.
    Art
    AKA Country Bubba (Older Than Dirt)
    Sep 2011
    31
    I do not know a lot about electronics but can follow instructions if well written or explained. So, when referring to the pins are you meaning the ones on the BOB or at the parallel port in the computer?
    Mar 2004
    1806
    The pin numbers on the BOB usually reference the same pin on the parallel port. So that is not a problem and the pull up and down resistors are on the BOB.
    I do not use that exact BOB, but most are configurable.
    IF you have pullup resistors and have the other end of the switches tied to +5V, then nothing will happen. Usually the best way is pullUP resistors on the BOB and tie the other end of the switches to GND. That way, when they open OR you have a wire break, it will stop the system.
    Art
  1. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  2. N/O limits and E-stop?
    By kevincnc in forum Servo Drives
    Last Post: 01-31-2013, 05:42 AM
  3. Home and limits stopped working
    By rezcar in forum Benchtop Machines
    Last Post: 07-09-2010, 02:07 PM
  4. Limits and E-Stop
    By rockcliffcnc in forum CNC Machine Related Electronics
    Last Post: 08-06-2009, 03:18 AM
  5. anyone help e-stop and limits
    By krymis in forum Benchtop Machines
    Last Post: 02-19-2008, 03:45 PM
