I am currently working with a Mori Seiki ZT1500Y lathe. I am attempting to use the external M codes M440-M449. When inputting one of these codes ( M441 for example) the machine will close corresponding relays for M445 and M446. I have a ladder logic book and I have no idea why the relay M441 does not work when inputting the M441 M code and so on. I am only using M441 as an example for they all hit random relays from what I can tell. Does anyone know what address map / parameters need changed to correct this problem? Any help would be appreciated.
Also, I have checked into the Ddata bits and they appeared correct. I have also seen the Internal relay in the ladder logic but I am not sure how they work.
Thanks.
Jim
