Hello Jason,
I've been busy so I did not see your post until today.
For the record, I have had my CNC6040Z-S80 for 11 months now and I am completely satisfied with it.
I have cut mostly plastic parts but have on one occasion cut some .062 steel plate, using a 1/8" Onsrud cutter @ 11,000 rpm, .015 doc. The
WD40 coolant mist smoked a bit but the part came out fine.
Having observed many issues with the typical EBAY router choices on this forum, I chose to get mine direct from CNC-Carving.
It was almost a turnkey solution …. take it out of the box, power it up, load up CUT2d and Mach 3, import DXF files from ACAD and cut parts.
Do get me wrong, there is a learning curve, bringing together this complete system, but that will happen no matter which system you get.
Today, the machine sits as I received it, no hardware issues what-so-ever. The only "tuning" I do is in the tool path setup for each job using
Cut2d. Can't remember changing anything in MACH3 after initial setup/configuration
here are the links to some photos of my machine and some parts I played with a few months back.
I haven't taken the time to post any newer pics.
Router-cnc6040 - a set on Flickr
and
http://www.flickr.com/photos/6428334...7633998424130/
