Hi everyone,
Im new to the site and need help with a 3 axis supermax mill with a fanuc om control. the parameters for this machine were lost and i've inherited the job of getting things working right. There are two things that bother me with the machine. The first is that when performing a tool change I have to input M6 then the tool number. This is backwards from every other mill I've ran in the past.
The second and more important part that bothers me is when this machine performs a tool change It goes past the tool change position all the way to z zero, then comes down to the tool change position and performs a tool. To give a little background at the end of a tool path we use a g28 to send it home and then run a sub program to perform the tool change. This is different from any other mill I've ran also.
What I'd like to accomplish is getting the tool change position set as some kind of home. We touch all of our tools off the mill table and then use a g54 to set z zero on the part. I've got the mill setup so it can read the relative position and input that into the tool offset. (originally we were writing down the length of the tool and then changing screens and imputing that into the tool offset manually.) The only problem is I have to manually zero out the relative position when i touch off tools so that it matches the machine position. (it normally reads z zero at the tool change position)
This is minor stuff but I'd like to get this machine as operator friendly as possible. My boss would like a lower wage operator to touch off tools and run parts on it in the future. Any help would be appreciated thanks guys.
