586,069 active members*
3,729 visitors online*
Thread: VB editor
    Nov 2010
    520
    VB editor
    Seems like the Mach3 VB editor is real straight forward editor. But I am having issues with it. I have been playing around with the Ref All Home button script (HiddenScript.m1s). On many, many occasions I make my changes, Save, and close it. When I go back and look at the file, the changes have not been saved. But then sometimes they are saved.
    So, any ideas what is going on? Something this simple is driving me nuts.
    Thanks.
    Rick
    Hiddenscript.m1s is not really the button script file, if that's where your looking. The button scripts are all saved in the .set file. Hiddenscript.m1s is just a sort of "dummy" name that the editor uses to work properly.
    Just use Operator >Edit button script. Make your changes. File>Save. Close the editor. To check if it's saved properly, use Operator > Edit button script again to look. I've never had an issue with this method.
    Nov 2010
    520
    Thanks for the info Gerry.
    I was using the Edit Button Script. Then I accidentally hit the VB Script Editor and the last file used by the script editor was HiddenScript.m1s, so I thought it shouldn't really matter how I got there. Consequently I was using both the Edit Button Script and the VB Script Editor interchangeably.
    I will make a point of only using the Edit Button Script.
    Rick
  1. using machineID editor
    By Brushtec_DB in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-13-2016, 11:01 AM
  2. 2d cad editor
    By 071203 in forum OpenSource Software
    Last Post: 09-25-2009, 02:22 PM
  3. NC code editor
    By grimy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-07-2009, 04:57 AM
  4. MC X Editor
    By cijunet in forum Mastercam
    Last Post: 02-21-2008, 05:28 PM
  5. Editor
    By Okuma_ray in forum Uncategorised CAM Discussion
    Last Post: 01-07-2004, 02:30 PM
