586,106 active members*
3,002 visitors online*
Results 1 to 6 of 6
    Apr 2005
    629
    Small hose clamps - screw to shaft coupling?
    Hi everyone,
    I am working on a small CNC machine (toy actually). It is using 1/4-20 threaded rod and NEMA17 stepper motors. I have the far end of the lead screw supported with bearings to provide thrust and radial alignment.
    For connection to the stepper motor, I am planning on using tubing (.186" ID). In my initial setup and testing, the tubing seems to hold well and drive the lead screws well. However, I know Murphy (of Murphy's Laws) very well, and I suspect as some point these tubing couplers will start to slip on me.
    The motor shafts are pretty short and the space there is pretty limitted so I can't use the regular screw-type hose clamps. I am wondering if someone knows of something small and compact that is available that could work for me in this application?
    Thanks!
    Chris
    Apr 2003
    1873
    Chris,
    How about making an extension shaft with a set screw that tightens to a small flat on the short motor shaft, making it long enough to use a hose clamp.
    Ken
    364
    This could work for you:
    http://www.esska.de/esska_eng_s/ear_hose_clamps.html
    At work we use the 2 ear clamp for compressed air and it works very well.
    The width for the smaller types is only .20 - .25 inch.
    Apr 2005
    629
    Hi Ken - I don't have any room for it - I didn't plan for that and am paying for it now in a cramped space.
    Lucas, that just might do the trick. I will order up some and give it a try.
    By chance, has anyone tried using a cable tie for this purpose. I don't think I need a lot of tension, this is more for "a little extra bit of holding power".
    Feb 2005
    578
    How about a solid shaft coupler?
    http://www1.mscdirect.com/CGI/NNSRIT...PMT4NO=5793174
    Steve
    Jan 2006
    2985
    just use a piece of wire and twist it tight with some pliers. think bread bag tie.
    Matt
