586,104 active members*
3,351 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Anyone know where to get this exact type of servo motor?
    Nov 2004
    44
    Found elsewhere in this forum.....
    The servo motors are 36VDC 430 oz/in peak. The peak amps is rated at 20. I just get a 36VDC 10-15 AMP power supply to run them. The encoder is 250 CPR which will translate to 5000 PPR when connected to a G320 drive. They will produce 1700 RPM and this is why I run them at a 2:1 ratio.
    The size of the motors are 2.26 dia X 6.2 long including encoder. The staft is 1/4" dia as sticks out .750 long.
    They are clasified as Nema 23 size. They don't have mounting brackets with them, they only have 4 6-32 hole on 1.531 B.C.
    Anyone know where to get these?
    Apr 2005
    1268
    Hey Coupe
    How are you getting 5000 ppr out of a 250 quad encoder with a g320. I replaced my 250's with a 500's just to get some resolution. Sounds like I wasted some $$$$. Are you in South Carolina???
    Just curious!
    billyjack
    :cheers:
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Nov 2004
    44
    Ok, I finally found a place that has them.
    http://www.seanet.com/%7Edmauch/
    I am just starting on this project and seen the stuff in my last post on this board and wanted the motors that it mentioned. So I do not yet get that kind of resolution because I am still building.
    Thanks all!
