586,103 active members*
3,717 visitors online*
    Jan 2013
    23
    Run Code at Startup
    As a follow on from my previous thread Is it possible to have Mach3 run some VB code at start up, if so how can this be done. My plan is to use VB code to put the Jog Mode into Cont at start up using OEM245.
    Barry
    Create the VB macro and save it as an M code, like M700.m1s, in your Mach3\macros\yourprofilename folder.
    In General Config, put M700 in the Initialization string. This will run it when you start mach3 and press Reset.
    Jan 2013
    23
    Seems my reply never made it!
    Thanks AGAIN Gerry for a quick response. All is working the way I want it to now.
    Barry
  1. Startup looking for VMC
    By autotechsteve in forum Want To Buy...Need help!
    Last Post: 10-15-2011, 04:27 PM
  2. HL-2 startup help
    By thum31 in forum Haas Lathes
    Last Post: 06-03-2009, 12:53 PM
  3. no startup
    By markjb in forum Fadal
    Last Post: 03-12-2008, 06:26 PM
  4. startup an shut down code needed
    By jrick in forum Fanuc
    Last Post: 02-09-2007, 05:38 PM
