586,389 active members*
3,161 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Replace old CRT monitor to LCD monitor
Results 1 to 10 of 10
    Hi!
    I successfull connected LCD monitor to my old Okuma LC30 with OSP5000L.
    I used this card:
    New Arcade Game RGB CGA EGA YUV to VGA HD Video Converter Board HD9800 GBS8200 | eBay
    Now I am searching the new monitor for it.
    What will be the best LED monitor for Okuma?
    Quote Originally Posted by =aike= View Post
    Hi!
    I used this card:
    Can you share the pinout? I have the same machine, the connector is a 20 pin male IDC and I am having trouble making it work. A pic or sketch will help a lot
    jolulank
    I will send you it next week.
    My electronics are in vocation now.
    Apr 2015
    Hi would you please share the pin out for the old 20 pin okuma crt connector? Thank you.
    dekbanpong
    [email protected]
    Dec 2015
    Re: Replace old CRT monitor to LCD monitor
    Hi .New to the forum .I also have a OSP 5000l-g that requires a new monitor. Did anyone share the pin out?
    Jan 2007
    37
    Email this guy for an easy drop in LCD Monitor. Adam Verin <[email protected]> part number is ML121CN5000; <$1400.
    TKBuisan
    None had shared the pin (:
    Dec 2015
    Do have a schematic?
    No, I have no CRT schematic.
    Red face Re: Replace old CRT monitor to LCD monitor- Okuma OSP5000 OSP5020 and OSP7000
    Okuma OSP5000 OSP5020 and OSP7000 CRT Monitor is a 12 inch color crt display.
    Replacement Specifications type: Okuma OSP5000 OSP5020 and OSP7000 Color LCD, industrial LCD panel, 20 pin signal connector, AC100-240V power supply , separate OSD keys,easy to mount and setup.
    https://en.elongshine.com/product-de...olour-monitor/
    Okuma OSP5000 and OSP5020 CRT Monitor is a 12 inch monochrome crt display.
    Replacement Specifications type: Okuma OSP5000 OSP5020 mono LCD, industrial LCD panel, 10 pin signal connector, AC100-240V power supply , separate OSD keys,easy to mount and setup.
    Okuma 5000 5020 mono Monitor
    https://en.elongshine.com/product-de...-mono-monitor/
  1. LCD Monitor
    By Dyad1 in forum Fadal
    Last Post: 06-25-2022, 07:20 AM
  2. Looking for info on how to replace my CRT monitor.
    By WmGuildenstern in forum Fadal
    Last Post: 12-09-2012, 04:31 PM
  3. Bad Monitor
    By eded59 in forum Fanuc
    Last Post: 10-21-2010, 08:44 PM
  4. HL-2 monitor very dim
    By 11toma in forum Haas Lathes
    Last Post: 08-15-2009, 04:17 AM
  5. monitor
    By rusticr6 in forum Haas Lathes
    Last Post: 10-25-2007, 01:06 AM
