586,082 active members*
3,758 visitors online*
    May 2013
    62
    Homing using limit and encoder index pulse?
    Does anyone have any sample code showing how to use the limit switchs and encoder index pulse to generate an accurate home position?
    Currently I have my limit switches set to kill drive I assume I need to change them to Dissalow drive into limit so I can run them to the limit then back off slowly until I see the encoder index pulse?
    Cheers
    Chris
    May 2006
    4045
    Hi Chris,
    To home to an index is pretty basic. It just involves an extra step after detecting the Limit to continue (or reverse) and wait for the index input.
    I've attached a parameterized function that should do this. Add the function to your home.c program and call it specifying all the listed parameters.
    HTH
    Regards
    TK
    http://dynomotion.com
    May 2013
    62
    Hi Tom,
    So
    axis = 0 for x, 1 for y, 2 for z etc (if channel 0 is x axis etc)
    speed = is in encoder counts per second? (encoder for position feedback)
    dir = +1 or -1?
    bit = 136 for first opto in? (do I remove the ! if my limits are active low?)
    indexspeed = is in encoder counts per second? (encoder for position feedback)
    indexbit = how do i reference this when it is connected to JP2 CHA_DIFFPLUS_4 etc?
    Polarity = I dont see this used?
    offset = is in encoder counts?
    Cheers
    Chris
    May 2006
    4045
    Hi Chris,
    yes
    yes
    dir = +1 or -1?
    yes
    yes, depends how it is wired
    with the ! it reads "wait while bit is not true"
    without the ! it reads "wait while bit is true"
    try both ways
    yes
    IO bit 36...43
    Polarity = I don't see this used?
    oops, see new attachment
    yes
    HTH
    Regards
    TK
  1. homing to index pulse
    By spoiledbrat in forum SmoothStepper Motion Control
    Last Post: 09-16-2012, 10:21 PM
  2. using encoder index for homing and a axes position
    By rokag3 in forum CNC Machine Related Electronics
    Last Post: 10-16-2009, 12:57 PM
  3. Spindle RPM control - Do I need an index pulse?
    By Lexx0001 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-27-2009, 07:42 AM
  4. How to use index pulse for homing purpose
    By Zig in forum LinuxCNC (formerly EMC2)
    Last Post: 03-28-2008, 08:16 AM
  5. spindle index, encoder, home/limit switch
    By Wm McNett in forum CNC Machine Related Electronics
    Last Post: 01-13-2006, 01:39 PM
