We have a Monarch 5024T mill and we are getting a lot of spindle noise at high RPM's. The spindle is a 12,000 RPM but we never run it that fast, about 8,000 max. Anyway, the higher the speed the louder it gets. Also, when we mill using x-axis it gives a rough cut, y-axis is not bad.
We replaced the x-axis ballscrew about a year ago and worked great so I don't think it's that.
We replaced the spindle bearings about 5 months ago and spindle stays cool.
We checked the play in the z-axis and if we use a lot of pressure we can move it about .002'' from side to side.
We checked the play in the spindle and with a lot of pressure we got about .005'' of play from side to side. We adjusted the spindle nut (could only move it a tiny bit until it was very tight) and then we had .003'' of play using a lot pressure. Checked the spindle play on our Chevalier 2040 VMC-L mill and we got .001'' play.
Could it be the bearings again? Any info or suggestions would be greatly appreciated. Thanks
