hey guys, I had a problem with a part I am cutting. the problem was, I used advanced rough to cut the profile of the part, and in one area, with advanced rough the tool doesn't go to .100 above part to rapid to next position, it only rapids to .100 above last depth cut, unless it thinks it will hit the part, and bob as well as predator did not show any tool hitting, but, my problem is the tool was hitting the part as it was rapiding to the next cuts start point. I don't think bob is at fault here. I think its a machine fault. is there a parameter, or a setting, or a G code that makes the machine synchronize the X and Y rapids so they travel in a " straight" line, arriving to a point at the sametime? as if they were feeding. I believe the tool was hitting because the Y axis was getting to its position before X. I know this can be done on most machines, but I don't know all the Haas systems very well, its a VF4, any help would be great.
