586,108 active members*
3,143 visitors online*
Page 1 of 3 123
Results 1 to 20 of 52
    Jan 2006
    387
    WOn't cut square!
    Add not cutting square to the list of things my machine won't do. It's a deepgroove, from eBay, they come with no documentation whatsoever.
    I'm just getting the hang of the design side, drawing a 4-inch square in a cad prgoram and converting it to gcode and watchign it go on the sim and then... big moment, run it on teh machine and... out pops something that's not a square. A 4-inch square is about a 16th out of square.
    So I think, 'Hmmm, what's causing that?' And I start tweaking the carriage frames a bit. Got them shimmed up for some compensation, let's see.... nope, still out of square.
    I'm cutting half-inch plywood with quarter-inch passes, it ought to cut through like butter, but it's not square. SO I redce both speed and depth and make more passes. Better but still nto square. I can get about a 64th of an inch out of square for a 4-inch square.
    And then just for grins I decide instead of cutting conventional, I'll cut climb.
    And it's square.
    So wassupwidat? Frame torque? Huh? What? Bit deflaection? Huh? How the heck do I handle THAT? THe spindle's a Bosch Colt, it's extremely securely mounted, so of course, it's probably moving.
    Anyone got any Hints? Tips? Donations?
    I doubt it's bit deflection, you're not pushing the bit very hard. Are all the sides perfectly straight? You were on the right track adjusting the machine to get it square. The small deviation from conventional vs climb cutting might be due to backlash.
    Jul 2005
    668
    conventional vs climb cutting???
    I know what climb cutting is, but it was my understanding that routing direction only had relevance in manual routing for operations like patterns, templates and edge forming using bearing bits.
    Is there a "conventional" direction for cnc cutting and if so what is it?
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Mar 2006
    1625
    Cutter outside of frame travel clockwise or cutter inside of frame travel counter-clockwise
    Jul 2005
    668
    Quote Originally Posted by lakeside
    Why? This opposite the way you route with a handheld.
    Steve
    Mar 2006
    1625
    if you cut the other way its called climb milling G41 and G42
    Climb Milling
    Cycle: Pocketing
    In the Pocketing cycle, the tool path moves always in clockwise direction. If this option is turned on, tool path movement is counter-clockwise.
    Jul 2005
    668
    So, is this just convention, or is there a reason to cut one direction verses the other?
    Steve
    Mar 2006
    1625
    when you climb mill there is little tool defection but if your cutting wood that not an issue chip of edge may occur in a climb mill more than a convention path
    Quote Originally Posted by Madclicker
    Whether hand routing or CNC routing, Conventional cutting would be going around the outside of your part CCW. Climb cutting is going around the outside of the part CW. You should never climb cut with a handheld router, for safety reasons. The bit will grab and want to pull the router out of your hands.
    What I've found when CNC routing wood, you usually get a much better cut when conventional cutting. But there are a few circumstances when climb cutting is needed. When cutting hardwoods, and cutting along the grain going CCW, if the bit is cutting along the edge of the wood, it's very likely that you'll experience tearout. Some woods are worse than others, with oak being about the worst. Climb cutting will allow you to make the same cut without getting tearout, almost all of the time. One exception is cutting arcs. Its possible to get tearout along an arc with both conventional and climb cutting, due to the grain direction changing during the cut.
    The best way to avoid tearout all together, is to always leave a little material on the waste side of the bit when cutting. This will always keep you from getting tearout, but depending on bit size, can waste a lot of material.
    Climb Milling
    Cycle: Pocketing
    Apparently your talking about a specific software here. G41 and G42 are tool radius compensation. With a standard spindle rotation, G42 (offset to the right) is always conventional cutting and G41(offset left) is climb cutting. It doesn't matter if your cutting pockets, or the outside profiles.
    Tool deflection CAN be an issue when routing wood. But, it's not very likely on a homebuilt machine unless your using bits smaller than 1/8".
    Jan 2006
    387
    Backlash would be an issue, wouldn't it? In a climb situations, bi deflection could be countering it. I took all backlash compensation out of the config after I was cutting circles and getting fun offsets And removing the backlash comp did make the squares a bit more square too, but after thinking about it, it would still be a factor. DAngit.
    Guess I need more brass shim material. ( sigh )
    Trust me, this deepgroove machine ain't all that.
    Jan 2006
    387
    Is this machine ever going to be able to cut accurately? It's got backlash, it's out of square... IS there really any hope for this hunka junk or am I screwed?
    If you can make it square and get rid of the backlash.
    Jan 2006
    387
    But how to remove the backlash? Tyring to cut circles tells me that backlash compensation is not the answer there. Dunno how to adjust for it. I've emailed deepgroove and asked bu so far no response. I don't see any anti-backlash adjustments to make on teh machine itself.
    You might have to change the screw and nut, if you can't get rid of it.
    Jan 2006
    387
    I was afraid of that. Might just try to upgrade to ball screws then. You're the link master, got any links to decent ball screws in the 18 and 36 inch lengths?
    Aug 2004
    2849
    Well I think you need to reduce the number of variables.....I would start by routing a straight line of a certain length using only one axis and checking the length....then I would perform the same set of tasks using the axis that is perpendicular to the one I just tested.....
    Jan 2006
    387
    ROuting a straight line on one axis of a certain length is sort of redundnat to the carriage movement measurement, but it WILL tell me if there's flex in the router mount somewhere. If I can measure .017 backlash on the carriage then if there's not a .017 discrepency on the line then I've got flex, right? This would be assuming that I ran the machine the opposite direction from the cut just prior to cutting, too.
    Dec 2004
    411
    Is it racking at all?
    Even if screw is central, it might still rack at the edge.
    Andy
    Drat, imperfection has finally stopped working!!
Page 1 of 3 123
