586,121 active members*
3,793 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 6M Kitamura mycenter 2 Tool change help
Results 1 to 6 of 6
    Feb 2006
    18
    When calling for a tool change in program what are the steps neccesary?
    I know M6 T10 But I must be missing something because it just sits there.
    and I know it works because I tried it in another program that was already
    in the control but when I enter the same info in my program it doesn't work.
    Dec 2004
    167
    You may need to command the Z axis to the refrance hight before the M6 command.
    Oct 2005
    34
    In MDI:
    T02:
    G91 G28 Z0 M06:
    Mar 2006
    1625
    T Must Come Before M-6
    Mar 2006
    14
    You can put t code and mo6 on the same line and in any order. In fact on the My2 it is better to have them on the same line because there is some tooling preselect software in some versions that caused the toolchanger to rotate to the new tool number but then it had to rotate back because it has to put the old tool back first.
    Mar 2007
    7
    kitamura tool height offset
    do any one guide me how to enter tool height offset as when i enter the value it does not accept
    also instead of 54,55,56..... offsets it has 1,2,3,..
    is it not possible to run with g54 offset in 6m and kitamua mycenter2 with 6m fanuc control
    also any one can send me parameter lis will be highly appreciated and thanks in advance
    [email protected]
