Didn't have much time lately but didn't forget this thread.
Originally Posted by
tt-boy
I cut a track and inserted a 100 ohm current limiting resistor before the 1uf cap and it seems to be OK. On that note I haven't got around to adding this resistor to my other machine and the modules are still working (haven't blown up yet)
How long that it will work depends on your machine settings. The transistor has some work to do only at low speed.
If your start speed and acceleration is high enough then it has to work for a few pulses at the beginning of a move, after these initial pulses the transistor has an easy job doing almost nothing. If you want a "will always work" solution: test it with the machine running at 1-5 step pulses per second.
I did some measurements and it takes approx. 70msec for a stepper motor to stabilise after a single step.
The step pulse width is only 1µsec for some 3D printer firmware.
The entire torque circuit must respond within 1µsec and remain active for 70msec (preferable longer for safety reasons).
This is quite difficult to get right with simple circuits, even a retriggerable one shot has difficulties to operate within these margins.
stern-69
I assume that if I want a kit (the one you designed) I go to MassMind and order it there. One question maybe you can help with, Can a kit be purchased (controllers and BOB) for 4 Axis, as Im thinking of driving the y axis with 2 motors (it runs the gantry, will be using linear rail system and ACME lead screws direct drive via motor). The machine will be about 24" x 24" max and used for PCB milling only, so I think smaller motors may work for me (once I figure that part out).
24" x 24" for PCB's only? That are large pcb's :-)
I would suggest to visit the "PCB milling" forum here, you will probably find very usefull info there.
Your setup is no problem, you can slave the 2 Y axis in software (Mach3 etc..) or connect the 2 drives to the same BOB output.
There are some differences between my BOB-drive setup compared with the Massmind one. Take a look and decide wich one suits you best.
srro
Is there any information around when the Dir-Signal should be stable prior the positive edge of the clock (Step-Pulse) and how long it should stay stable (in relation to the positive or negative edge of the clock (Step-Pulse)?
I had a quick look at the latest datasheet and can't find it neither.
There are more spec's missing, like the max. output current that can be drawn from the internal 5V regulator.
On top of this they have changed some other parameters wich required some component changes in my design.
I have a design ready and it's in use on a Mach3 mill and 2 3D printers, all 3 are working fine. It will be released when I find some time to compile the documentation and update the website.
Open source CNC electronics and accessories:
http://users.skynet.be/ldt/CNC%20electronics/THB6064AH.html
