Re: TB6600 drive from EBAY
Originally Posted by
amina
i have problem with my tb6560. X and Z axis motors work fine. Y axis motor starts to run uncontrollably (and it gets hot) when i plug tb6560 to power. It twitches during that movement. I can't jog it with Mach3, the only time when Y axis motor doesn't is when RESET button is blinking, when i hit it its starts to move again
i hocked up everything correct and setup mach3 and checked out numerous time, and don't have idea whats wrong
Does anyone have a solution?
A. This thread is about the TB6600. Please post your question on any of the /hundreds/ of threads where people are asking for help with those crap TB6560 drivers.
B. TB6560 drivers were never intended for use in CNC systems. The power on sequence is incompatible.
C. Why aren't you asking the people who SOLD you the driver for help? Why should WE support cheap Chinese crap?
And finally.
D. What happens if you swap the drivers around? Does the issue follow the driver or the axis?
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
