Hi
I have idea to make hotplate diameter 300-350mm at the middle dinner table, it will up screw up and down when finished by touch switch.
what common z table and easy to find (up down 0~30/40 mm) any idea?
Hi
Good Morning,
You may want to look at some of the commercial router lift kits and DIY alternatives. Clever people out there. The idea is to support the lift on both sides squarely so that there is no binding. Then you can use a screw and nut with a motor and limit switches. Automatic window lift drive from a car??
