586,112 active members*
3,251 visitors online*
    Jul 2013
    622 Tool Arm Fault alarm
    Have the "622 Tool Arm Fault" alarm, on newer VF5SS. Problem is, it's before the machine is fired up. I can't power up servos with this problem present, and I can't debug or recover without the servos powered up. Is there a manual way to force the arm back into position (not lowered, just slightly rotated), or bypass the alarm long enough to get the machine fired up? Thanks.
    Mar 2010
    1852
    Don't do a power up, home the axis's only. Zero return all axis's and you should be okay to work on it. See if that will work.
    Mike
    Feb 2010
    1184
    Quote Originally Posted by b1kem1ke View Post
    Define "Fired up".
    When you turn on the machine you should be able to clear all alarms before homing the machine by pressing the RESET button once for each alarm. At this point you should be able to go into tool change recover mode.
    Oct 2010
    I was able to solve this problem on a VF2SS by going into the parameters and disabling the tool changer. Then I was able to power up/restart. When I did this I noticed the arm move slightly. I then re-enabled the tool changer and then everything worked again.
  1. Alarm 134 Tool Clamp Fault
    By Xeno in forum Haas Mills
    Last Post: 07-30-2013, 10:08 PM
  2. 126 Gear Fault Alarm
    By super95awd in forum Haas Mills
    Last Post: 10-11-2012, 09:43 PM
  3. Alarm 190 B Motor Z Fault
    By yc00146 in forum Haas Mills
    Last Post: 07-24-2012, 08:06 PM
  4. Alarm 142 A Motor Fault
    By ToyMaker94566 in forum Haas Mills
    Last Post: 11-29-2011, 07:10 PM
  5. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
