Got Mach 3 running smooth except for
there is always that except isn't there? I was finally forced to move to Mach3 and am now using an Ethernet SmoothStepper. This has been a saga of failure upon failure and I won't go into them except the one.
I have my 4th axis set up as angular and motor tuned with correct units per to get a correct 360 rotation with mdi !!! My problem is I cannot get Mach to recognize my reference switch set as a home only, or even if I set it as a limit. I have tried the switch as hi and lo, the switch as nc and no. The bob led blinks as the switch is activated when the shaft moves by it, but that is all. Is does not stop to reference nor does it stop if I set the switch as a limit switch.
I am homing/reffing in the negative and have to move a touch in the negative to get off the switch. I have not thought to home in the positive. Would that help me with this?
Mike
No greater love can a man have than this, that he give his life for a friend.
