I am wondering if anyone has tried diecutting the outer diameter of a hexagonal rod. If so, are there any tips you can give on picking the correct die to match the extruded hexagonal rod. I am wanting to use the hexagonal rod as a guide rail, whilst being able to thread the end with enough thread to tighten a nut, not needing to hold much force. Thanks for reading this.
