I have googled for reviews or any comments related to bigger laser cutter machines ( 1300 x2500 ) labeled as 1325 , but nothing could be found on Google and forums .So both to continue to get help and to do some payback for all the help i got here I wanted to leave a thread about the purchase and machine quality. Hopefully this will be useful to folks interested in buying direct from china in the future.
We have just received new bed size (1300 x 2500) Laser cutter from G-weike China. We purchased the model LC1325 with RECI W6 tube and MPC6565 based controller with almost all machine parts as spares for our future safety with handful of laser lenses. Since we already had LC6090 80W Reci from Gweike ( Detailed story will be posted soon) , which we bought 3 months back and happy with their excellent after sales support( even on Holidays), we blindly placed order to Lucy at GWeike with below Specifications.( Certainly with enough negotiation and price comparison with competitors ).
Laser Cutter LC1325- 130W (Minimum power) W6 Reci with below features
Working Area 1300 x 2500 mm (Should be exact size)
Leetro latest 6565 series Based DSP Board.
LCD Display with USB based PC Interface.
Necessary Licensed Software CD (LaserCUT 5.3 or Higher )with Keys
130W (Minimum power)RECI Laser Tube (W6) 80mmx1650mm - (10,000 Hrs Life)
High Quality RECI compatible laser power supply ( Reci Make DY20)
3 Phase Stepper Motor on all axis
2nos motors for Y axis.
Molybdenum-Mirrors (>25mm)
USA Make Lenses
4" Lens as standard (>25MM Dia)
Air Assist feature with High Power Compressor
Powerfull AIR blower (>=750w)for removing dust from working table (2 Nos or more)
CW5200 Water chiller
USB Port for Connecting USB Stick
Red dot Pointer
Ammeter for laser current.
Knife shape platform (Aluminium)
Power Supply: 220V-240V, 50 HZ.
With Castor Wheel and Fixed Height adjustable legs
All other Standard items as per your mail and User manual.
Minimum One year Warranty for all above items
10 months warranty for Laser Tubes and optics.
Optional Items Required
Extra 6565 DSP Controller kit (Leetro board+lcd+soft dog+ects)
Old Type Rotary attachment for Odd shaped items.
Auto Focus
Partial up-down table (Half Portion 1300 x 1250)
Honeycomb platform 2 Nos (1300x1250) , ( to be covered in Full size)
HEPA Air Filter for Smell and dust removing (3 Stage)
130w spare laser tube Set-RECI(W6) 80mmx1650mm -(10,000 Hrs Life)
Extra Power Supply for 130w Laser (Reci Make DY20)
Extra 2" lense Set (>25mm) = 2 Nos
Extra 3" lense (>25mm ) = 2 nos
Extra 4" lens Set (>25mm dia) =2 nos
Extra 1.5" lense Set (>25mm) = 2 Nos
Extra Nozzles if required for above Lenses.
Extra Suitable Nozzle for 1.5” Lens
Extra belt set = 2 nos (full set , 2 nos)
Extra stepper driver
Extra stepper motor
Extra Stepper motor power supply (SMPS)
Extra Bearings Set
Extra mirrors set (3 Nos)(Molybdenum-Mirror)
Extra laser head & mirror mount complete set (full set)
Eye Protect Glass
The crate was very very big, we rented a truck to bring it to our shop and it barely fit into the back of full size truck ( Tailgate and one side gate would not close) and they have to remove it temporary. They kept second wooden box ( Air filter) on top of the bigger box.We used local workers( 10 workers) to unload it , they were very well trained and not used any forklift. First they removed wooden pieces on all sides and top side, then slide it through the end of the truck and slowly placed down. Once it is on ground they removed lock on wheels and rolled in to our shop.
Once it is inside, we unpacked it fully and we could not found any visible physical damages, so we were happy with a big relief . The wooden packing was excellent and could not be easily damaged. Immediately we checked all items to make sure everything is as per our Purchase order . Almost all items were as per the PO,but two items were not there in the package. Since it is bigger laser cutter and needs two Ex-host Fans , but only one was there along with the package, LCD Panel was also not there for spare MPC6565 Controller kit ( Controller card+ LCD Panel+ Dongle) ,.
We also noticed there is no RECI brand sticker on the both laser tubes even though metal Rings at cathode side is marked with RECI ,We confirmed the length is same as per RECI website for W6 laser tubes. I have to ask lucy at G-weike regarding this.
