Re: 5 X 3 router Need input on bearing spacing
That looks like the concept for a very capable machine. I like it.
Hard to say what the *optimal* bearing spacing is, since it is a trade-off between rigidity and motion range. The further you space it apart the lower the tilting load will be and consequently the contribution of the bearings to flex.
But at some point there is diminishing return and you just lose too much usable movement. Without deep scientific study I would say if you space them about as far apart as the maximum leverage length between the bit tip and the bearings you are probably good. Given that you are using high quality rails you can probably go a bit more compact. For the Y-axis you can also help by moving the rack/pinion as low as possible or using a double rack to eliminate the twisting load and resulting racking on Y and Z bearings. But the latter is probably a bit overkill.
Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
