586,042 active members*
3,696 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21i - Can the PMC be used to interface a non-Fanuc 4th axis
    Jan 2006
    175
    I have a yaskawa driven harmonic drive system that I would like to be able to use as a 4th axis on a custom-built cnc router. Having given some thought to how one might interface such a thing, it begs the question of whether or not there is any way to directly interface the fanuc control to the yaskawa drive in a manner that would allow it to show up as a contollable axis? while it would be nice to be able to use it without limitations, I would be happy with just being able to use basic indexer functions.
    The Yaskawa drive I have for this includes the optional indexer module, so I can interface it several ways. For basic indexer functionality, the most promising looks to be a direct serial connection that I could run to the second serial port on the control. The drive then uses a command/response language where the control could issue (using POPEN, DPRINT, PCLOS):
    POS 1638400 (16 bit encoder, 50:1 reduction, this would rotate 90 degrees)
    The indexer responds:
    1OK (Drive 1 OK, when command completes)
    Can anyone shed any additional light on whether or not there is a means to directly interface third party hardware like this with the control/PMC in a manner that would allow the rotary unit to be considered an axis? Is there any way to have a program halt execution and wait for the incoming OK response before continuing?
    Jan 2006
    175
    Correction. The output to the indexer would be:
    POS 1638400
    SPD XXXX
    ST
  1. Solidcam Fanuc 3-4-5 axis Mill and Fanuc 2-3 axis Turn Posts (2013)
    By calver in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-04-2021, 07:34 PM
  2. I need an Interface to Fanuc 18i-TB
    By Tobia in forum Fanuc
    Last Post: 08-30-2012, 03:23 PM
  3. Fanuc 16i MA, COM interface
    By marek-vavra in forum Fanuc
    Last Post: 06-02-2011, 03:35 PM
  4. New Fanuc interface
    By andypugh in forum Servo Motors / Drives
    Last Post: 01-06-2011, 06:59 PM
  5. Replies: 0
    Last Post: 05-29-2007, 11:45 PM
