586,443 active members*
2,732 visitors online*
    Jul 2013
    Unhappy Motion Controller
    My CNC machine, multicam 1000, plasma is down. I think the motion controller, M2545, manufactured by Extratech is the problem as its inputs are receiving power but there's no power at the outputs. Only one of the four lights is showing from the device. However, I opened the damn thing and there was no soot or scent of something having burnt out. Same thing for everything in its circuit.
    The supply cable of the extraction motor was really warm at the time and I think this is where the problem originated as the earth cable was burnt on the end connected to the earth terminal, and since they shared this terminal.
    The problem is that I'm stuck at the moment. How much does this thing even cost, how can I be sure its the problem?
    Jan 2008
    2247
    The Extratech controller is custom made for MultiCam. I suggest calling their tech service department....they are very good at supporting the machines they have in the field!
    Jim Colt
    Quote Originally Posted by Joshua Sendawul View Post
    Jan 2007
    599
    are you fixed up or do you still need some help. M2524 have a handheld pendant, does that power up? can you get a connection in motion mechanic?
  1. CNC USB motion controller
    By Kroko in forum News Announcements
    Last Post: 01-03-2014, 01:58 PM
  2. Choosing a motion controller
    By spangledboy in forum Controller & Computer Solutions
    Last Post: 03-31-2013, 11:07 AM
  3. Motion controller recommendation?
    By cnczoner in forum Stepper Motors / Drives
    Last Post: 03-31-2010, 04:48 AM
  4. Yaskawa Motion Controller
    By curtisturner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2008, 07:27 PM
  5. the Motion group Controller
    By 47MLB in forum Machines running Mach Software
    Last Post: 07-23-2007, 10:16 PM
