586,103 active members*
3,304 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How to build without shielded wires.
Results 1 to 9 of 9
    Jun 2006
    47
    Noise comes from lots of things; we know that already, data wires are what picks up this noise and causes havoc to the very sensitive Parallel port.
    Now if we think about it, no professionally made machine has data wires running all over the place like most hobbyists insist on doing, if we don’t have data wires, then we don’t have problems with noise.
    Ok, how.
    Motor wires create noise, but not affected by it, so we can save on the shielded wire here.
    Limit switches are nothing more than a safety switch, so why not wire it up like one,
    One or two E-stop switches and all limit switches, all wired in series (24 volt), no problem with noise, again shielded wire isn’t needed.
    Home switches (wired parallel) of any type can be found in (24 volt) versions, again no problem with noise, no shielded wire.
    E-stop and limit switches should always have their own hard wired circuit fully independent of the computer, but it is also an advantage if the computer receives the E-stop signal as well.
    In the control box the E-stop circuit uses a large relay, by having another small 24 volt relay connected in parallel very close to the breakout board, now it’s here we have data wires, very short, no problem with noise, no shielded wire, and we do the same with the home circuit, another small 24 volt relay.
    PS:
    Limit switches are something you don’t run into every day; in fact you shouldn’t touch them at all,
    just like E-stop they should be wired closed (the safest way), a strong switch with a solid ramp that can force open a sticking contact, wired this way a loose contact or a broken wire will create an E-stop.
    35538
    The main problem is that there's not an inexpensive method of using 24V for switches.
    Jun 2006
    47
    All switches (E-stop), relays and wiring involved in a 12-24 volt circuit are standard off the self (cheep) easy to find components, whereas shielded wires of the type needed for CNC work isn’t cheep at all, if you can find it.
    35538
    What I meant was, how do you interface 24V switches to the 5V parallel port?
    Mar 2004
    1806
    to my way of thinking, why not use an opto isolator to do the interface from 24V to the 5V required by the parallel port?
    Art
    AKA Country Bubba (Older Than Dirt)
    Jun 2006
    47
    My E-stop circuit uses a contactor (Relay) to switch off power to the whole system, by having a small relay connected in parallel to the main relay I can send an E-stop signal on to Mach3.
    The 5 volt from the Bob is connected to the small relay, (picture above).
    The second relay is input from home switches.
    Jun 2006
    47
    Ok, this is not the best drawing in the world,
    Two circuits one E-stop and the other Home, the only data wires involved are just 100 mm long.
    Jun 2006
    47
    Oh ****, I messed up that post, I’ll have to try again.
    Sorry guys
    Jan 2011
    14
    Thank you, I am one of the lucky ones; as I discovered this before I started wiring.
    What you say makes sense and seems to duplicate what real factories use for their robotics.
    However, your blueprint isn't as clear as it could be as your data wires are all contained within
    a steal panel which shields your data wires.
    It is my hopes that I can get my mind around this circuit as my LIMIT sensors are PNP which means
    I have rethink your awesome circuit and my LIMIT sensors which provide voltage 10-30 volts when
    activated.
    Thanks for the thread I have subscribed and I will be back when I get to the wiring.
    Edoc
  1. Replies: 3
    Last Post: 10-26-2010, 11:49 PM
  2. What wires should be shielded?
    By eat in forum CNC Machine Related Electronics
    Last Post: 07-23-2007, 05:16 PM
  3. Shielded versus not shielded cable.....?
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 05-23-2007, 01:55 PM
  4. Shielded cable help please.
    By Oldmanandhistoy in forum CNC Machine Related Electronics
    Last Post: 04-02-2007, 01:05 PM
  5. DIY shielded wires
    By HogDog in forum CNC Machine Related Electronics
    Last Post: 04-14-2006, 01:02 AM
