586,609 active members*
3,717 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Turn 3D Printer into Milling Machine
    Nov 2011
    Hi, I have a 3D printer (reprap) uses Arduino board. At the moment I am using open source 3D printing software to operate it.
    I am planning to replace the printing head with a Dremel or Die Grinder, and use it as lightweight milling machine.
    My question is what is you recommended open source or low cost CAM software that may work well. It has to be able to detect the control board via USB. I know that many CAM software works with parallel port only.
    Thank you.
    Nov 2012
    46
    I don't own a mill or a 3d printer, so you are miles ahead of me,
    Never seen a 3d printer turned into a mill. Not sure that a 3d printer can push a tool into/through materials. Mills are allot more ridged as far as side to side deflection versus a printer. Also, can a Reprap support the weight of the tool?
    I have see discussions on turning cnc routers into 3d printers or cnc mills. Perhaps the way to go is to buy a kit without electronics and use your controller and stepper motors.
    Nov 2011
    Thanks for the reply. I am using a Zen toolwork platform which was designed for cnc application. it used leadscrew and drives using high torque nema17 steppers. The issue I have is the arduino controller I used has a usb interface, which many cam software not supporting.
    I have done a bit research since and found grbl firmware and it's associated cam software did support ardiuno controller. The problem with grbl is that it won't work for 3d printing. I'll have to upload 3d printing firmware when printing, and change to gbrl firmware when milling. It's not ideal.
  1. eccentric turn milling
    By promach in forum Okuma
    Last Post: 12-01-2013, 03:47 AM
  2. 3D printer head in a milling machine?
    By vinot in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 03-01-2012, 07:47 AM
  3. Please Help! - How to use G19 with G12.1 in Mazak Turn Milling Mode
    By afrancoc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-16-2011, 02:56 PM
  4. paper printer machine like cnc machine ???
    By patriciooholegu in forum Mechanical Calculations/Engineering Design
    Last Post: 08-08-2007, 02:19 AM
