I am in Australia and seek the following steels for prototype testing.
Down in Oz our local suppliers do not import either of these steels (nor are they interested in doing so)
The steels required are:
Maraging 250
EN39B
Material sizes which follow are suitable for our application and are the minimum dimensions per piece required.
I require a total of 6 pieces of any of the following sizes for each type of steel.
Cutting tolerance on all pieces is +/-5.0mm
All dimensions are metric mm
Any of the following are suitable in Maraging 250 and EN39B
(1) Plate: Stock 20mm plate x 200mm x 200mm (Thickness can be approx 25.4mm (1") to 19.05mm)
(2) Round Bar:-
(a) Dia 63.5mm plus (2.5") x 200mm long
(b) Dia 210mm x 20mm long
(c) Dia 250mm x 20mm long
Please advise availability and lead times.
I will arrange airfreight and couriers directly from you to our facility.
Cheers,
Alex
