Originally Posted by
yellow68gto
Okay hello everyone, Im mostly a lurker but I have a couple questions.
back story first.
machine is a vf-3 made in November of 1996
In Feb. this year we had what I though was a bearing in our vf-3 spindle go bad.
called out our local Hfo tech and they said it was gear box and motor. replace gear box and motor and somehow they wiped out the I/o board during motor replacement.
After being down 1.5 - 2 weeks its up and running (this is our production work horse, practically had the owner crying that it was down so long. I had our 4 double vises on a tm1 trying to keep up)
Come to find the noise is still there. but tech leaves after "checking" everything. go to run my first batch of parts and find the spindle is turning backwards and then I have an alarm for low transmission fluid pressure. ad fluid call the tech he fixes spindle direction. claiming our spindle bearing are fine and the new noise is from the new gear box.
so after complaining multiple times and month have gone by running on a bad bearing I needed some more work done not related to the spindle but made sure the new tech could diagnois the sound. and he comes back with a bad spindle bearing after disconnecting the gearbox and belt and running motor. then I gave him the low down on our history with the machine.
now the new gear box and motor are good for 10k according to the packaging with the motor.
now we replaced the spindle last week with one that also states good to 10k
I want to know what else I may need to replace upgrade or parameters I need to change to get to 10k. our local hfo says they no longer do these upgrades.
any help would be appreciated
Ken
