586,060 active members*
4,200 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > Toyoda FH400J - Memory card & Ethernet
    Jul 2013
    Question Toyoda FH400J - Memory card & Ethernet
    Hi, I've got a Toyoda FH400J with more or less no viable documentation regarding this subject so I hope that someone can answer two questions for me if it's not too much of a bother. I would be very grateful.
    The machine has an installed memory card reader at the control panel and an ethernet socket at the back just in case. Now I've tried transfering NC programs via the memory card, bought one(8GB) as well as the adapter for the slot so everything fits perfectly but when ever I try to access the card an error says:" memory card is not formatted ".
    Despite formatting it on a Windows machine(Fat32) it still says the same so my guess is that it's simply too large in size which is so often the problem with CNC machines. Is that the case here? This is a generic memory card.
    My second question which is secondary in terms of importance is regarding the ethernet. We have some short on paper hand written documentation about this, basically I've set it up like this:
    CNC :
    IP : 192.168.1.1
    Mask : 255.255.255.0
    USername : generic
    Password : generic
    PC :
    IP : 192.168.1.10
    So far , I am able to ping the CNC machine from the PC successfully.
    I know that I need to run a FTP server software on my PC and I have tried that with FTpZilla server but to no success. The CNC machine actually hangs when I try to make a connection. Ethernet is secondary on my list, it's something I would love to use as far as communication goes but with the lack of any actual documentation I simply cannot get it to work. Any tips or guides on this would be much appreciated!
    Feb 2011
    hello,
    I use a 2G card bought from ebay for 5$ and is working fine (Fanuc 32-i)
  1. Do I need a separate video card with a Ethernet Smoothstepper?
    By kevincnc in forum Machines running Mach Software
    Last Post: 02-19-2013, 05:12 AM
  2. Reading memory stick through ethernet port?
    By Buda15 in forum CNC Machine Related Electronics
    Last Post: 11-19-2012, 11:35 PM
  3. Haas TM-1 Ethernet card failure
    By cryo in forum Haas Mills
    Last Post: 01-13-2012, 11:52 PM
  4. Fanuc 0i-MC ethernet card
    By motordude in forum Fanuc
    Last Post: 05-28-2010, 06:11 PM
  5. ETHERNET CARD - NET GEAR ISA EA201
    By SpeedMetal in forum Milltronics
    Last Post: 02-06-2008, 10:16 PM
