586,290 active members*
3,870 visitors online*
Results 1 to 6 of 6
    Jul 2013
    12
    Over travel Z axis
    I have a 2005(ish) Sharp SV2412 that has been sitting idle for 2-3 years (I'm new at this company). I'm trying to get the machine back up to a point where it's useable. I've already done all the obvious stuff (oil/coolant flush). I'm at the point where I'm trying to figure out how to home the machine.
    When I start the machine up, and switch to zero return mode, I get an "overtravel Z" error and the Z axis position from the machine position menu is +1.9812. I can see that it hasnt tripped the limit switch for home yet - so how do I get it to travel back to the home position? Is there a battery I need to replace for the encoders since the machine has been idle for a number of years?
    2932
    Power down the control. Hold the P and CAN buttons while starting the control. When it gets to the main screen release the P and CAN. This will temporarily ignore the soft limits so you can home it.
    Jul 2013
    12
    Quote Originally Posted by dcoupar View Post
    That did it. Thanks
    Re: Over travel Z axis
    Hello everyone, this is a little different issue.
    When running the program normally and when the machine z axis go to tool changer position for the next tool change the machine stays hanging at M6 line and it won’t execute the tool change. I have currently 5 tool changes in this program and it does it randomly and sometimes won’t do it.
    Any ideas?
    Any ideas?
    Sep 2021
    Thanks for an other fantastic topic. I really like the way you present it. Official website
  1. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  2. C axis over travel
    By Andy Fritz in forum Fanuc
    Last Post: 03-08-2013, 12:24 AM
  3. U Axis excess error + Y axis over travel?!!!
    By jaine in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2013, 06:45 AM
  4. Z axis travel
    By dgapilot in forum Shopmaster/Shoptask
    Last Post: 08-17-2009, 01:55 AM
  5. x4 Y axis travel
    By cvafiadis in forum Syil Products
    Last Post: 11-12-2008, 08:54 PM
