586,704 active members*
2,495 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > >Collet Slipping on .625 carbide drill
    Nov 2007
    29
    Drilling with live tool on lathe using holder that has ER25 collet. Keep locking the machine up during drilling. Determined the problem is the drill slipping in the collet and overloading the thrust axis. I know it would be better with a 40 collet but don't have it. Anyone have any tips on improving the torque capabilities on these minimal size collets? Tried using a diamond file to put a little "tooth" on the shank but still slipped. The drill shank is glass smooth so the collet just can't grip it.
    While collets are a good help in a machine shop, they tend to slip when you apply a certain amount of torque. When doing milling or drilling, your best bet would be to use either a Weldon holder, which is easy to get and relatively cheap, or hydraulic type holder, or a shrink fit holder.
    Mario
    Feb 2009
    6028
    Ya, just try finding a Weldon holder for a live tool lathe...
    If your collet is not sprung, and torqued to spec (think its supposed to be about 90lbs on that size, I'd have to check my rigo collet chart) you could put a little lapping compound on it and re try. Not the best solution, but may give it that extra bite.
    Edit: 77 pounds
    http://www.techniksusa.com/metal/torque_chart.htm
  1. drill bit slipping in er16 collet!
    By jbrookes in forum MetalWork Discussion
    Last Post: 12-27-2012, 04:01 AM
  2. what do you use to cut off carbide drill bits and carbide endmills
    By micksphoto in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-01-2012, 03:28 PM
  3. Is there a trick to keep taps from slipping in 3 jaw drill chucks?
    By slashmaster in forum Benchtop Machines
    Last Post: 01-19-2011, 03:07 AM
