Hi, maybe a long shot but I desperately need someone local from GTA area who can help me set up my Torcam CNC Milling machine. I have the original 1993 controller box which controls the steppers and the DC spindle, was only able to move the Y axis in one direction. There is no info on the net about pin allocation and with my limited experience in Mach3 after trying many pin allocation combinations I could not solve the problem, I’m simply lost in Mach3 and don’t know enough about electronics to test the controller components
I’m wiling to pay or I will let you use my machine anytime you need to cut something, so as long as I have it you can come in and use it and teach me about Mach3. It’s a solid machine with 10”x 10”x 6” travel, R8 spindle. I also have a Hardinge 9” lathe I’m willing to share.
Cheers
