586,113 active members*
3,614 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Taig modification to increase Y axis travel
    May 2013
    480
    Attachment 193988
    This should be self explanatory, let me know if it isn't.
    btw: i drilled out the 10-32 screws and replaced them with 1/4-20.
    the steel is some mystery 3/4" thin wall pipe, pretty lightweight but sufficiently strong.
    You're going to gain at least a solid inch of travel before the Y axis slide comes too far off the machine.
    Also why the heck did Taig not go with the tapered X axis gibb (sp?) design for the Y axis? they used it for the z axis as well...
    another mod to gain another half inch is to take the entire Y axis aluminum plate and the two steel ways.. and move that about half an inch further away from the back of the machine, you will then be able to send the y axis off the end of the ways away from the operator. (but you'll have to drill and tap 8 more holes.)
    May 2013
    480
    Re: Taig modification to increase Y axis travel
    Further modification to increase Y axis travel while also allowing you to tighten the leadscrew nut without taking the entire mill apart:
    Drill out the 3/8th inch hole with a half inch drill, just deep enough for the leadscrew nut.
    Grind down a 1/4-20 countersunk machine screw (or mill a space for a washer, or find a 10-32 bolt that has a head larger than 3/8th diameter) and thread it for 10-32.
    Countersink the top of the 3/8th hole for the screw.
    Drill out the bronze lead screw and tap it for 10-32.
    http://johansense.com/bulk/taig/P1050527.JPG
    the stepper will need to be shifted over.
    positioning is critical because the leadscrew nut will be run all the way up to the end of the screw.
    Jul 2015
    4
    Quote Originally Posted by Eldon_Joh View Post
    Attachment 193988
    Just before joining this forum, I did the same, but used two 3/4 aluminum square tubing bolted together as I was worried about twisting. Now looking to extend the YZ axis, any picts?
  1. Anyone increase their z axis travel 6040?
    By jimmineycricket in forum Chinese Machines
    Last Post: 03-29-2014, 05:16 PM
  2. Taig spindle mod to increase stiffness.
    By Eldon_Joh in forum Taig Mills / Lathes
    Last Post: 05-08-2013, 05:36 AM
  3. CNCFUSION Deluxe kit--Increase axes travel
    By Crevice Reamer in forum Benchtop Machines
    Last Post: 01-06-2010, 06:24 AM
  4. Taig Modification
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 10-05-2008, 03:10 PM
  5. CNC Fusion and Hoss travel increase mod
    By Clot in forum Benchtop Machines
    Last Post: 04-26-2008, 03:37 AM
