ran into a problem today during a pocket cut where my z zero would change about 1/4 inch during the run. i also noticed the mach coor DRO also changes the same amount. i checked for slippage by scratching all connectors on the z and they are rock solid ( no movement). i also tried a dry run (cutting air) and it did the same thing after the first or second pocket was cut? the zero change would always be in the negative direction about 1/4 inch. any help would be appreciated. also been tying to get ahold of artsoft and any help there would be appreciated thanks again bill
