So, I have a part that is held in a fixture as per the drawing attached. Grey is the fixture, blue is the workpiece held in place by a fixture clamp. The fixture is designed to be held in a vise with the lower left corner set to X0 Y0 so I can plop it in the vise, touch off, and machine away.
The DXF has the part drawn so its lower-left hand corner is X0 Y0. So in order for the toolpaths to be in the right place, we have to apply an offset somewhere. The Machine Setup option in the CAM tree *seemed* like the right place to do this. When I put in .3 for X and .93305 for Y, the little coordinate system arrows went in what looked like the right place up and to the right of the part. However, when I clicked to recompute all toolpaths, they didn't move. I ended up just moving the part on the drawing canvas so that its origin was where the fixture put it, but this feels like a hack. I could have programmed G55 to have the origin in the right place and then posted the toolpaths with work offset 2, but that also seemed like a workaround.
Is the machine setup option the right way to handle something like this, and if so, how would I actually use it?
