586,114 active members*
3,221 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Best Surface Mothod
Results 1 to 12 of 12
    Feb 2012
    40
    Best Surface Mothod
    Hi there,
    I am trying to create a surface, can someone help me achieve this?
    With "Surface-Net", I was able to create a surface, but this surface doesn't have the contour I need.
    I tried a few different methods but was unsuccessful and "Surface-Net" was closest I got.
    In photo #3, the surface doesn't follow the cross rib lines and off the contour. How do I make it
    follow the lines?
    "Surface-Swept" sounds promising, but I just couldn't figure out how to use it.
    Please see the attached photos if interested.
    Thank you so much in advance,
    KenAttachment 194180
    Attachment 194182
    Attachment 194184
    Apr 2003
    3578
    Share your file please.
    Cadcam
    Feb 2012
    40
    Smile File attached
    Hi there, the file's attached! Its Mastercam X5.
    Thanks!
    Also added in:
    PRE X files and IGES file formats
    Attached Files Attached Files
    Feb 2012
    40
    Hello, just uploaded the file for your review, any inputs mean a lot to me... Thank you.
    Sep 2010
    7
    I cant open that. I have MasterCAM X3. Save it in Older MasterCam version OR IGES file.
    Feb 2012
    40
    Hello, just added two more files, Thank you!
    Apr 2003
    3578
    Here you go in X5 and made with net surface this touch's all curves.
    Cadcam
    Feb 2012
    40
    Wow, very good. Would you be kind enough to how you selected each chain?
    I tried this 'net surface' and didn't come out like this one. Thank you! -Ken
    Apr 2003
    3578
    I picked net surface used window around the wire,Then picked the lower left hand corner as the search point and set for along. that's it.
    Cadcam
    Sep 2010
    7
    Wow that's amazing that works so nice. Some of that wire frame is not even touching each other and it trimmed it up beautifully. I never knew to use this. This is great to know.
    Apr 2003
    3578
    High_Speed the other option was to go back to the old option of Coons surface that is a Chook these days but this was replaced back in the beginning of X series of MC to replace Coons complexity.
    Cadcam
    Feb 2012
    40
    @cadcam Sounds nice, I'll try this thing myself. Hopefully I can generate the same beautiful surface as you did Thank you so much!
  1. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  2. Surface over a surface problem
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2011, 03:42 PM
  3. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  4. MX3 SURFACE TO SURFACE TRIM
    By 82rouled in forum Mastercam
    Last Post: 05-18-2009, 06:02 PM
  5. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
