586,062 active members*
4,656 visitors online*
Results 1 to 7 of 7
    Jul 2012
    18
    Possible new machine? Need opinions!
    I found an older AXYZ router for sale. The seller says it's about 20 years old. I have not been able to find a model number or year of production.
    Does anybody have any information on this machine? The seller is asking $4,000. Is this a deal for a setup minus computer and software? Thanks
    Attachment 194460
    Attachment 194462
    Feb 2005
    85
    F15pilot,
    The condition of the machine in the photo is problematic to me. There no labeling etc. to indicate who made it.
    It is not in pristine condition, with lots of possible problems.
    Wear, alignment, and 20 year old electronics to name a couple.
    I would certainly want to visit the shop and give it thorough look see.
    While it is a nice table size, one could spend a lot to refurbish it.
    One other thing, where is it located relative to your location ? Shipping could be expensive.
    Just my thoughts on the subject ..... definitely not a turn-key proposition.
    Apr 2004
    5737
    I don't see $4,000 worth of useful parts there either. The table itself is probably still okay, but the rest of it is iffy at best. You can't expect 20-year-old mechanical parts and electronics to function correctly and the motors, if they aren't worn out, are obsolete. It certainly doesn't look like it's in working condition to me, and even if it was, I think you'd be further along if you spent your $4k on new parts, rather than this worn-out and neglected old pile of junk.
    Andrew Werby
    www.computersculpture.com
    Re: Possible new machine? Need opinions!
    only considering the development of CNC technology, you are buying a structure only.
    Jan 2007
    96
    I bought mine (quite like yours) and upgraded it with Clear Path motors, all new wiring, all new electronics (UB1 and EC3eth) and UCCNC. It came with 2 Perske spindles, valved vacuum bed with t-slots. No ATC. It'll run all day for days at a time (if I have the work) if I ask it to. My investment in the end was what I would easily call reasonable to in the end have a 5' x 10' machine. Just sayin'...
    lyheater Guest
    Application of 1.5T Hydraulic Tilting Melting Furnace :
    The steel shell furnace is mainly used for melting steel, iron, copper, aluminum and alloys. It has the characteristics of high melting efficiency, good power saving effect, uniform metal composition, less burning loss, fast temperature rise and easy temperature control. It is suitable for various metals melting.
    Jan 2007
    96
    Some don't get it. Personally, I get a big kick out of making something out of nothing (or little). It was a learning experience for me to take mine from surplus to serious, but with the help of this forum (especially Ger and others), I'm way ahead. Try to determine the "tightness" of the machine and go from there. If you're machine is sound (do they ever really wear out?) and you have time to pick at it as I did, you'll be glad where it takes you. If you want some additional encouragement, go price a new 4' x 8' or 5' x 10' machine.
  1. machine opinions
    By The Furian in forum Cincinnati CNC
    Last Post: 01-28-2019, 12:42 AM
  2. BZT-CNC Machine opinions / reviews
    By rjb in forum Commercial CNC Wood Routers
    Last Post: 04-26-2014, 08:57 PM
  3. Opinions wanted on this machine
    By Aegir in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2013, 07:53 AM
  4. Need opinions on machine design
    By extreme in forum DIY CNC Router Table Machines
    Last Post: 07-15-2013, 11:39 PM
  5. Opinions on First Machine for Newbie
    By jbothell in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2008, 06:49 PM
