586,036 active members*
3,521 visitors online*
    Apr 2010
    18
    20 amp requirement
    I talked on the phone with a guy at Tormach about the 20A circuit requirement and was told it wasn't really necessary, so I went ahead and switched one of the 15A outlets to a 20A without actually changing the circuit. Now I'm having some issues with getting the spindle started on my new 770. As soon as I hit the spindle start switch, the circuit breaker flips and I lose power to the shop. I'm able to jog the machine and turn the controller on just fine, but I guess their draw isn't nearly as much as the spindle. Not being a big electric guy, I'm assuming this is because I actually do need the 20A circuit? Just want some confirmation before I call the electrician out.
    Stephen
    Apr 2010
    18
    Actually, I'm thinking it's the GFCI tripping that's causing the power to go out.
    Apr 2010
    18
    Yep, that was it. Thanks for the help.
    Feb 2008
    389
    Congrats on your new 770 and welcome to the forum.
    Glad you figured it out.
    Currently using SC7 Build 1.6 Rev. 64105
    Sep 2010
    166
    The only time my 770 tripped my 15A plug was when I taking a max power cut (6061, 0.065" DOC, 3/8" full slot, 60ipm), with a 1/2hp fan, 275+ watts of lighting, and 1hp air compressor going.
  1. Powermax65 Air Filtration Requirement
    By Genopsyism in forum Hypertherm Plasma
    Last Post: 02-04-2012, 02:22 AM
  2. how can I calculate the Torque requirement?
    By bpp in forum Stepper Motors / Drives
    Last Post: 10-20-2011, 05:16 PM
  3. CFM requirement
    By plasticplus.com in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-12-2011, 06:54 PM
  4. Thermal Dynamics A-120 power requirement help
    By hailrazer in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-21-2010, 01:40 AM
  5. min requirement of PC for install and run EMC2?
    By szcharle in forum LinuxCNC (formerly EMC2)
    Last Post: 03-01-2007, 03:53 PM
