586,115 active members*
3,341 visitors online*
    Feb 2007
    85
    Which CAT 40 pull studs?
    So I need to get some more pull studs to go with all the tool holders I have been buying. The machine is a Tree 325 Journeyman. It takes the same pull studs/retention knobs as a Mazak or Fadal machine (the short fat little buggers with the 45° angle at the end). So where does everyone get theirs from? I am liking the price of the Pull studs from Shars, but the made in china aspect of them leaves me to wonder how reliable they will be. From the sounds of it, fishing a broken pull stud out of a spindle is not a fun task and something to be avoided like the plague. Is there such a thing as a high quality, inexpensive pull stud? Or should I just suck it up and pay $10-20ea for the "nicer" or made in the usa ones?
    Feb 2009
    6028
    http://www.retentionknobsupply.com/
    And I don't blame you. Seen multiple retention knob failures over the years. Takes out the spindle taper every time.
  1. Haas Pull Studs
    By rrbmachining in forum Haas Mills
    Last Post: 08-12-2013, 01:22 PM
  2. What pull studs
    By zcases in forum Fadal
    Last Post: 11-03-2012, 10:54 PM
  3. Pull studs – use thread locker?
    By helocat in forum Haas Mills
    Last Post: 06-09-2010, 05:17 AM
  4. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
  5. Tree vmc1050 pull studs
    By rbpower in forum Tree
    Last Post: 03-06-2009, 06:31 PM
