586,121 active members*
3,758 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Upgrading from -2 to -5... what parameters do I need to record?
    Jan 2009
    107
    Ok, I've decided to bite the bullet and upgrade all my cards on my 1990 4020 from my current -2 control to the -5 control with 8Mb of mem. Hopefully I will be able to communicate at 38K or maybe 115K instead of my current 4800 baud and should have plenty of memory to store smaller programs.
    With this upgrade, I get to swap out almost all the cards since all my cards are too old.
    What all should I record before I do the swap? I took pics of the following screens:
    SETP
    Fixture
    Tools
    Backlash
    Are there any others I'm forgetting that I will need once the new cards are installed?
    Any other words of advice before I make the swap? I'm assuming there really isn't much to it other than swapping cards and resetting the parameters.
    Thanks for the help!
    Apr 2005
    108
    everything what you need is on the pendant door
    Apr 2005
    1194
    No it is not you need your ballscrew pitch error comp numbers, backlash and SETP parameters that is all
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
  1. Scm Record
    By TechMo in forum CamWorks
    Last Post: 12-20-2012, 02:54 PM
  2. SCM Record 2 NUM 750
    By branchy in forum DNC Problems and Solutions
    Last Post: 03-24-2012, 10:47 AM
  3. For the record
    By denmar in forum Fadal
    Last Post: 09-01-2011, 07:51 PM
  4. SCM Record 121
    By craigy85 in forum Commercial CNC Wood Routers
    Last Post: 03-08-2008, 11:38 PM
