586,835 active members*
2,731 visitors online*
    Dec 2004
    783
    Parallel port pci card
    Been helping a friend out with his plasmacam machine for a while now, would get frequent low voltage warnings, and it was tricky to get the controller to turn on and initialize without unplugging the parallel cable first.
    Installed a pmdx 5 volt dual parallel port card tonight, loaded the driver from the included disk, turned the parallel port off in bios, and now it's all working perfectly. No more low voltage warnings, and the machine controller turns on and initializes properly every time with the cable connected.
    Also started to figure out the auto/digital height control, pretty cool stuff!
    Sure wish plasmacam had a sort of settings library you could edit and select based on the material your cutting...
    Dylan.
    Sent from tapatalk
    Sep 2012
    1543
    My buddies plasmacam has a library, mine doesn't, I think its because I have the cheap DesignEdge software that comes with a GoTorch.
  1. Parallel port add-in card.
    By Drools in forum Gecko Drives
    Last Post: 06-27-2012, 06:40 PM
  2. PCI parallel port card
    By Smooth90 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-13-2011, 05:17 PM
  3. Which PCI parallel port card?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-03-2010, 07:32 PM
  4. PCI 1 port parallel card
    By noyloj in forum Machines running Mach Software
    Last Post: 12-03-2009, 12:22 AM
  5. PCI Parallel Port Card
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2008, 04:03 AM
