586,075 active members*
3,967 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > metal and nonmetal laser cutting machine 1325
Results 1 to 1 of 1
    Jul 2012
    83
    Smile metal and nonmetal laser cutting machine 1325
    Products:
    IntroductionLC1325M is a mixing cutting machine, specialized in cutting stainless steel, carbon steel, MDF and acrylic.High efficiency: The cutting speed of 1mm stainless steel is 1800 mm/min.20mm acrylic with perfect cutting quality.LC1325M machine is matched with the Panasonic Servo System and high precision.ball-screw system to ensure the high precision, running stable and long-operation.The sheet metal is not flat. But the system can sense a distance from the nozzle to the metal surface and follow the surface up and down to automatically adjust the certain focus distance for keeping high precision cutting quality.The laser beam is expanding, so the bigger the working area is, the more difficult the machine is to get the same cutting quality over the whole working area. The fixed beam optical system can guarantees the consistent beam power and quality over the whole working area so that the machine can get the same cutting quality.High efficiency, high precision, stable performance and long life.Low running cost about 5KVA/hour.
    Features Laser tube (150w)High precision ball-screw system
    Untouched following system
    Fixed beam optical system
    Industrial chiller
    Off-computer controlling system
    Application
    Laser power 150w
    Material Acrylic MDF Stainless steel Carbon steel
    Cutting thickness 30mm 10mm 1.5mm 1.5mm
    150W Cutting speed
    Material Cutting thickness Cutting speed (mm/min)
    Stainless steel 0.5mm 2700
    1mm 1800
    1.5mm 1000-1200
    Carbon steel
    0.5mm 3000
    1mm 1800
    1.5mm 1000-1200
    Acrylic 10mm 300
    20mm 90-120
    MDF 10mm 300-400
    Technology Parameter
    Model LC1325M
    Laser power 150W
    Working area 1250 × 2500 mm
    Positioning accuracy ±0.05 mm
    Positioning speed 20m/min
    Weight 1000 kg
    Power supply 220V±10%/10A
    Standard configurition:
    1, USB port
    2, RECI laser tube (150w)
    3, Chiller LW-16&air pump(precision 0.1degree)
    4,Japan Panasonic servo motor(high precison)
    5,Taiwan HIWIN lead screw&linear guide
    6,Y axis DUAL lead screw
    7,National Auto-adjuster (Charge Sensing)
    8, German copy laser head
    9 ,Z axis automatic tracking
    10, American Imported 26 mirrors &focus(water colled)
    Attached Thumbnails Attached Thumbnails Japan Panasonic servo motor.jpg   laser head.jpg
  1. The cheapest metal &nonmetal laser cutting machine LC1325
    By gweikelaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-09-2013, 04:38 AM
  2. Thin metal laser cutting machine- CHEAPEST metal laser cutter
    By Gweikelasers in forum News Announcements
    Last Post: 03-06-2013, 10:08 AM
